sergei wrote:My thermodynamics is very rusty, but please bear with me:
One would think once the air is de-pressurized then it will drop temperature to similar temperature it started with (ambient) + temp gained from turbo inefficiency (isenthalpic process aka irreversible adiabatic process due to drag). Adiabatic process is going in both directions, you compress gas it will heat-up, you decompress gas it will cool.
steve murch wrote:to run a bov is more important than where but there is some differences.
if you recirc back to the intake just after the turbo outlet the charge air temp is high,close to t/b after the cooler the temp is down.
i on the other hand prefer not to run one at all but theres abit more to doing so without hurting the turbo in the process.
JustinSpiderholden wrote:steve murch wrote:to run a bov is more important than where but there is some differences.
what is required not to have to run a blow off valve?
