ae101 4agze troubleshooting (no spark)
Postby cogent » Sun Nov 22, 2009 6:34 pm
OK, I have an aw11 with a AE101 4AGZE in it.
I'm running the stock ECU with a cut-down harness (possibly root cause #1).
Turning the key to STA will cause the starter to crank the engine over.
With the key set to IGN;
12v at the injectors
12v at the coil plugs
12v to the igniter unit
12v to the fuel pump
however! no spark at the sparkplugs!
I have tried the following to remedy this issue
Confirmed that all 4 wires from the CAS have conductivity at the ECU plugs
Confirmed conductivity between the igniter and the coil plugs
Confirmed conductivity between the igniter and the ecu on pins IGF and IGT
Ground the igniter unit and confirmed conductivity between the igniter casing and random parts of the engine bay/chassis
I'm pretty much at a loss for where to go next. I know the CAS and coils are ok, because i have had the car running using these parts with a link ecu.
cogent
Postby cogent » Mon Nov 23, 2009 9:01 am
anyone in wellington have a AE101 4AGZE that I can test my igniter unit in? bonus points if i can test my ECU at the same time (but i understand if this is too big a hassle due to the location of the ecu in the dash).
cogent
Postby jakesae101 » Mon Nov 23, 2009 10:27 am
ignitor not the same as a ae92 4agze?
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby cogent » Mon Nov 23, 2009 10:37 am
cheers, ive managed to find a igniter on trademe now so hopefully i can find a way of eliminating the ecu as a root cause also.
cogent
Postby slighty_sykotic » Mon Nov 23, 2009 12:26 pm
Do you have 12v at all those points during cranking?
slighty_sykotic
Postby cogent » Mon Nov 23, 2009 1:33 pm
I'll check that tonight!
cogent
Postby cogent » Mon Nov 23, 2009 5:44 pm
ok i've done a quick check. The ignition switched source i'm using drops to 9v during cranking. This is the same at the coils also. Im going to setup a relay that is switched with ignition but provides 12v from the battery, to see if that helps.
cogent
Postby gasman » Mon Nov 23, 2009 6:10 pm
how fresh is your battery?
i got a ignitor lying around if you want it for a $15 if you want it.
"What can possibly go wrong?"
gasman
Postby cogent » Mon Nov 23, 2009 6:19 pm
$15 sounds like a deal. Is it a AE101 4AGZE one? Think you could give it to Sue and i'll grab it off him tomorrow?
I'll go try a different battery now, the one i'm using is putting out 12v and has been on charge overnight, but its not the newest. Also trying a different battery eliminates another root cause I suppose.
cogent
Postby cogent » Mon Nov 23, 2009 6:36 pm
new battery, same result of between 9.5 and 9.99v (did not peak to 10v on the mm).
cogent
Postby themaleman » Tue Nov 24, 2009 6:43 pm
try jump start it, simple and workd for me 8)
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
