fivebob wrote:Adoom wrote:Burn the evidence! Burn it all!!!!!
Only if you pay the carbon tax for that fire first
I can pay that at the post office? What forms do I need to fill out?
fivebob wrote:Sure it's an important issue, but it's not necessary to loose all common sense and ability to evaluate the information that is presented to you in a rational manner. From what I can see neither side of this debate is prepared to evaluate evidence that is contrary to their opinion. Without informed and rational debate the problem, if it exists, will not be solved.
From what I can see we do have global warming, but whether or not that is entirely man made is debateable,
but you'd have to be very ignorant to believe that man has nothing at all to do with it. The other issue, which I believe needs to be separated from the argument over what is causing it, is whether man can do anything to reverse the trend to any significant degree.
anthonym wrote:I have looked and have not been able to find any tangible evidence (i.e. not modelling or surrogate measures) that anthropogenic CO2 is causing warming. Or in fact that atmospheric CO2 has a measurable impact at all relative to the impact of water vapor, in the real world, as opposed to laboratory and computer models.
I'm not sure what data you are looking at but the warmist scientists have admitted that the temperature has been static or cooling for the last decade (and that their models did not predict this).
And the actual measured rise (if the carefully preened and manipulated data can actually be trusted) is only about 1 degree centigrade over the last 100 years.
Anecdotal data on crops is all fine and well, apart from the fact that the same sort of thing also ocurred hundreds of years ago.
it could be regarded as somewhat grandiose to suggest that man can affect the climate of the planet given what else is at play;
I hope that's all rational enough for you.
HZRDIZ wrote:Two Words - "Pole Reversal"... True story right there...
And no, it has nothing to do with what your mum gets up to on a saturday night...
