jakesae101 wrote:dont you hate it when this happens i thaught i really should do an oil change on the trueno as i havent done one on it in the 8 or 9 months ive owned it turns out the previous person to do this job did the filter up tight as $&#$% and didnt lube the seal so it ended up the filter got munted so i had to get a screwdriver and tap the filter round 4 hours to change the oil normally takes me half a hr max share your experiances people
Leon wrote:jakesae101 wrote:dont you hate it when this happens i thaught i really should do an oil change on the trueno as i havent done one on it in the 8 or 9 months ive owned it turns out the previous person to do this job did the filter up tight as $&#$% and didnt lube the seal so it ended up the filter got munted so i had to get a screwdriver and tap the filter round 4 hours to change the oil normally takes me half a hr max share your experiances people
Same job, same issue, same engine.
In an MR2
Oh what a fun day that was.
In an MR2
Dell'Orto wrote:Trying to undo the filler plug on my AE101 Levin...has been done up tighter than a tight thing. Rounded it off with a socket, heat and CRC havent made it budge. Have nearly cut the thing in half trying to turn it with a cold chisel and its still not moved....
