Spigot Remover
Spigot Remover
Postby -Justin- » Sat Feb 13, 2010 12:16 pm
Hey dont know if this is the right section but if anyone in gisborne has a spigot remover that will work on a RB20DE could i borrow it please for a box
-Justin-
Postby Burning Angel » Sat Feb 13, 2010 2:23 pm
im pretty sure theyre the same size as an SR20,
i just filled the cavity behind the bush with grease and stuck a 1/2" extension in the hole and whacked it with a hammer
cheap and easy
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby soopachargen » Sat Feb 13, 2010 6:13 pm
Burning Angel wrote:im pretty sure theyre the same size as an SR20,
[img]image[/img]
cheap and easy
hydraulic spigot remover
When in doubt, down and out.
soopachargen
Postby shihad » Sun Feb 14, 2010 4:02 pm
you fill me with confidence justin
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby deaf_rattle » Sun Feb 14, 2010 9:03 pm
cheap and easy
yep, thats the correct way to do it. seems odd when you hear it for the first time, but it work.
Postby rollaholic » Sun Feb 14, 2010 11:32 pm
it usually works, if a bearing is particularly tight though its possible for the grease to push through the races and out the front again, or out around your 1/2 inch extension etc.
have had to smash one or two out in the past, you can get a slide hammer type tool for them but in my experience if its too tight for the grease trick to work the slide hammer version just rips the inner out of the bearing anyway
Postby Burning Angel » Mon Feb 15, 2010 9:46 am
rollaholic wrote:it usually works, if a bearing is particularly tight though its possible for the grease to push through the races and out the front again, or out around your 1/2 inch extension etc.
tis not a bearing on SR20/Rb engines, its a sintered bronze bush, so no probs there.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
