Mr Revhead wrote:sea legs behind the ear from 12 hours before the trip![]()
Quint wrote:celica_xr9145 wrote:I know that new air freshners make me feel car sick
'new car smell' does it to me. Never get car sick otherwises.
Crampy wrote:Tell them all to harden the f*ck up!
sergei wrote:DeeCee wrote:rubber band with a piece of paper underneath on the wrist. Acupuncture trick. Used to work for me when I was younger
Most likely to be placebo.
Malcolm wrote:I understand motion sickness tends to be mostly related to vibrational frequency, it's possible that doing something like changing your tyre pressures, changing suspension spring rates (i'd suggest increasing rear or decreasing front spring rates, should reduce pitch oscillations over bumps)
Audi wrote:As stated earlier, ginger should do it. Mythbusters found it the best cure for motion sickness by far.
edwagon wrote:Malcom - good suggestion - Last week I had just been playing with the rear damper settings to get rid of the pitch, without going too harsh in the ride. I might tighten it up another notch and see how it goes.
