ISC ST215
ISC ST215
Postby AW11 Turbo » Mon May 10, 2010 4:33 am
can anyone tell me which type the ISC Valve on a ST215 is?
i've some troubles controlling it with my haltech e8
this is how i've wired it:
Pin1 BAC output Haltech
Pin2 +12V
Pin3 GND
AW11 Turbo
Postby fivebob » Mon May 10, 2010 10:04 am
**EDIT
Stock wiring is;
Pin 1 - ECU (PWM sink to earth via RSO Pin)
Pin 2 - +12v
Pin 3 - GND
Postby AW11 Turbo » Mon May 10, 2010 10:08 am
are you sure???
is this wiring diagram wrong?
Uploaded with ImageShack.us
AW11 Turbo
Postby fivebob » Mon May 10, 2010 10:14 am
Oops, I read it wrong, your wiring is correct :oops:
Postby AW11 Turbo » Mon May 10, 2010 10:24 am
ok :)
is it right that the coil witch is under permanent current closes the isc and with the second one i can open it?
should be a rotary one? (i havent open it while rebuilding the engine)
AW11 Turbo
Postby fivebob » Mon May 10, 2010 11:36 am
Not sure, here is the only info I have. if you can translate it you may have the answer ;)
ISC valve
Postby Pirken » Fri Jan 13, 2012 12:23 am
Did you manage to get it to woork ? I have the same problem with my st215 and AEM ems. I can only get it to open half up. When the AEM is on 100% open the valve is only at 50% opening.
Have a LHD Caldina 1999. And i love it !!
Pirken
Postby sergei » Fri Jan 13, 2012 8:08 am
What part of diagram you want translated?
Here is the explanation how Toyota ISC works:
http://www.autoshop101.com/forms/h26.pdf
Scroll down to rotary type of ISC.
Users browsing this forum: Bing [Bot] and 16 guests
