frost wrote:is that if they throw everything at him? seems so cheap to take a life in this country,
The vehicle inspector's report showed Austin's car had been modified suspension "only suitable for a controlled environment like a race track".
Mr Revhead wrote:Hell no
track suspension is much much harder.
Too hard = unsafe on roads.
cat007 wrote:Mr Revhead wrote:Hell no
Because tracks are smoother than NZ roads?
cat007 wrote:The vehicle inspector's report showed Austin's car had been modified suspension "only suitable for a controlled environment like a race track".
Only suitable for a controlled environment? You mean designed to perform rather than for comfort? Am I missing something there? Or wouldn't a race track suspension setup perform (read: handle) better than one designed to soften bumps etc?
sergei wrote:cat007 wrote:The vehicle inspector's report showed Austin's car had been modified suspension "only suitable for a controlled environment like a race track".
Analogy here: is trying to compete in Paris-Dakkar rally in a stock standard corolla.
Think what happens when you have hard suspension if you go over a substantial bump? it will skip. While the wheel air born you get no traction, no stopping and no steering for that wheel. With softer suspension it will follow all the bumps maintaining traction.
