the fallen303 wrote:1j and 2j water pumps are almost identical, so shouldn't be an issue.
The GE's and GTE's are different for the 2J, so I wouldn't be surprised if there was some variation between the 1J and the 2J
have you checked the ignition timing?
trd-drifting wrote:How can i make sure there is no air locks or bleed it correctly? wouldnt 500kms of normal driving force the airlock out due to the coolent expanding?
Also what rpm does standard 2JZ turbos kick in as it seems a lot laggier than my 1JZ. I have removed all the little valves and solonoids and the butterfly valve in the intercooler piping so both turbos spool at the same time. Full boost (12psi) took till 3600rpm according to the dyno charts and im sure my 1jz was like 2800rpm.
Josh
trd-drifting wrote:The GE's and GTE's are different for the 2J, so I wouldn't be surprised if there was some variation between the 1J and the 2J
Im 99% sure it should be fine but the pump was brought from toyota as a 2JZ pump i put on my 1JZ to get rid of the hydro fan setup as i don't have a hydro fan and they are so bulky as well. Lots of people change them over and do not have any problems. Also i changed the pump on my 1JZ just before i broke it, and it wasnt sitting around for long and bearings are fine and there has been no rubbing etc..
have you checked and double checked that the fan is blowing the correct way? i have seen it time and time again. people come in with an over heating car, especially those dope skyline/cefiro/laurels that people put the big alloy cores on and they wire the fan backwards.
using your hand is not good enough, because u can mistake fan air draw for pressure.
u need to use a piece of paper and see if the fan 'sucks it' onto the radiator (or in your case, sucks it onto the fan)
also, is it definately over heating? i know that using the wrong temp sender for the link ecu's or not having the ecu calibrated right can cause it to read wrong and seem is over heating.
i had issues with my 2jzgte in my cressida. i had the standard cressida radiator, twin fans, and a 700x600x120 intercooler infront of it, a huge unit, i thought that was the issue. but it came down to not having any coolant in the system (as i had just got it all running and hadnt had a chance to flush it with coolant) and only a 13psi cap. once i fixed them it was sweet. about 30 dyno runs. 3rd gear linelocks over 300 metres long before the temp would start climbing.
and also, the water pumps are the same. i ran a soarer 1jzgte waterpump on mine.
trd-drifting wrote:I removed a few frost plugs
rollaholic wrote:'coolant' is no better at cooling than water, by the way.
strx7 wrote:I know it is reccomended for R32 GTR's to run 100% water for track days on std radiators.
Do i read that right that water nearly has twice the heat transfer of anti freeze?
sergei wrote:2.394 J/(g K) for e.glycol
vs
4.18 J/(g K) for water
FLAWLES wrote:MAGN1T wrote:The headghasket is probably still leaking because the block wasn't "decked".
Pretty common on JZs if you talk to an engine reconditioner.
Steve
