ATAl wrote:The engine has only run for 5 to 10 mins so far so maybe it just needs more running? So any ideas?
allencr wrote:ATAl wrote:The engine has only run for 5 to 10 mins so far so maybe it just needs more running? So any ideas?
Wishful thinking, not a chance in the world that it will get better by itself.
I'm constantly amazed at the engine noises that are mistakenly diagnosed and then finally pinned down as really coming from an exhaust leak!!!!!!!!!!
There are 20 valves and they will ALL sound the same with similar lash/gap.
The valves make noise at 1/2 engine speed, a rod bearing will be twice engine speed & change when that cyl's spark/fuel is disabled, the VVT I got no idea but is by far the most common one for sure. [/b]
l1ttle_d3vil wrote:Not the injectors ticking? Some of them can be pretty noisy...
ATAl wrote:Also, ran a sound pulse generator on my laptop set to half engine speed and it matches the sound coming out of the engine's speed.
CXGPWR wrote:What has been done to the engine?
I pulled down a 4AGE 16v that was noisy(i thought it was tappets on first listen, measured & they were all fine.
Turnes out the pistons were hitting the serface of the head just slightly.
Cause = thin head gasket + skimmed head.
pc wrote:CXGPWR wrote:What has been done to the engine?
I've had this exact problem, and the engine was a bit noisy from the rebuild. The engine ran for about 1.5 years, then the piston eventually cracked enough and pressurised the sump too much and I had to pull the engine out and have another go.
