Custom strut brace
Custom strut brace
Postby 2win2rbo » Fri Aug 13, 2010 6:02 pm
Does anyone know a shop that fabricates strut braces?
2win2rbo
Postby atmosports » Fri Aug 13, 2010 6:05 pm
Any place that does fabrication work should be able to do it for you, else pretty much any motorsport/performance shop should be able to do it. HiTech Motorsport & motorsport Fabrications are two names that spring to mind amongst others
atmosports
Postby celica_xr9145 » Fri Aug 13, 2010 6:05 pm
Where are you located too?
www.Garage-X.org - Car Awesomeness
Facebook.com/garagexnz - Now on FB!!
95' Zenki Silvia S14, 99' BMW 328i E46
celica_xr9145
Postby 2win2rbo » Fri Aug 13, 2010 6:43 pm
celica_xr9145 wrote:Where are you located too?
I'm in North Shore City, Auckland. Any shop in Auckland would do.
2win2rbo
Postby touge_ae101 » Fri Aug 13, 2010 7:45 pm
what are you after/what are you aiming to do by having a strut brace? i have been making a few and selling them.
heres the thread;
viewtopic.php?t=78209&highlight=
give me a PM or check out my build thread if you want to know more.
touge_ae101
Postby 2win2rbo » Fri Aug 13, 2010 11:15 pm
I just want to increase the body rigidity of my SXV15 because I hate to hear squeaking from the inside especially when going on and off the driveway.
2win2rbo
Postby touge_ae101 » Fri Aug 13, 2010 11:51 pm
are you looking at front or rear strut braces? have you tried to see if the ae101/111 std braces fit?
i can make anything to size if thats what you want but it is easier if i have a car to work off.
touge_ae101
Postby Bling » Sat Aug 14, 2010 1:29 am
2win2rbo wrote:I just want to increase the body rigidity of my SXV15 because I hate to hear squeaking from the inside especially when going on and off the driveway.
Not bushes worn or something similar?
Postby Adamal » Sat Aug 14, 2010 1:58 am
Yea, squeaking to me would indicate the sway bar bushes are worn.
Have a look at them and you'll probably find the whole the bar goes through is an oval shape, and is probably dry.
Postby 2win2rbo » Sat Aug 14, 2010 1:18 pm
I've already replaced all the sway bar bushes with Nolathane. Anyway, I'm just gonna check the suspension again just to make sure.
2win2rbo
Postby Adamal » Sat Aug 14, 2010 3:03 pm
Did you use the grease that came with them or did you put them in dry?
Postby 2win2rbo » Sat Aug 14, 2010 4:43 pm
Adamal wrote:Did you use the grease that came with them or did you put them in dry?
Yap, I used the grease that came with them.
2win2rbo
