Oil return on 1jzgte front sump
Postby drift-monkey » Tue Aug 17, 2010 3:46 pm
I swapped my mid sump to a front sump to clear the swaybar, but now i cant seen to get the mid sump return flange to line up with the front sump flange? is the peice that bolts onto the side of the sump with the two oil return hoses different, has anyone got any idea of a quick fix so i can get my engine in the car asap :) cheers
drift-monkey
Postby spencer » Tue Aug 17, 2010 3:56 pm
Yea they are different, if you cant find one, toyota will supply one for around ~$50 last time I checked. If you can fab you could whip one up pretty quick
ms63 crown
spencer
Postby drift-monkey » Wed Aug 18, 2010 4:04 pm
bugger toyota want 190 bucks for one stuff that
drift-monkey
Postby Looonie » Wed Aug 18, 2010 4:24 pm
Got a pic of the one you need, or the one you've got so I can make sure not that?
I've got a few floating around in the garage, ones probably a front sump return.
Rumple dee pumple dee doo...
Looonie
Postby spencer » Wed Aug 18, 2010 4:25 pm
gutted did someone ask for a special price for you? doubt its that expensive if you know someone
ms63 crown
spencer
Postby Glancn » Wed Aug 18, 2010 6:07 pm
I think you can modify it, That what Joel did on his onevia.
Glancn
Postby drift-monkey » Tue Aug 24, 2010 9:35 am
drift-monkey
