Smokey 4AGE Blacktop
Postby CXGPWR » Mon Aug 23, 2010 1:31 pm
I have a smokey 4age blacktop, only really smokes when its being trashed.
Eg 4 laps of manfield will chew through 1 litre of oil.
Has anyone tried the Brasso or sandblashing sand down the intake?
( i dont care about the motor so might give it a go )
Thoughts?
lol
CXGPWR
Postby Mr Revhead » Mon Aug 23, 2010 1:48 pm
Are you going to try this mod?
Postby MR2BOY23 » Mon Aug 23, 2010 2:47 pm
This won't end well
MR2BOY23
Postby CXGPWR » Mon Aug 23, 2010 2:52 pm
Not that directly no, i have done it to my lawnmower & boy does that thing go now! No smoke either.
Ill give it a go, There are plenty of blacktop's out there & this ones f**ked anyway + its only a blacktop.
Ill post videos if i get around to it.
CXGPWR
Postby Mr Revhead » Mon Aug 23, 2010 2:53 pm
:o please do......
Postby AE92-5ONIC » Mon Aug 23, 2010 2:58 pm
Mr Revhead wrote:Are you going to try this mod?
The comments are halarious!
omg........ stop driving that thing and toe it to someone that will kick you in the nuts and take the car off your hands and go buy a honda
The problem is, you did it wrong. You gotta do the fuel system sand blasting treatment first. 25lbs in the gas tank, and THEN 25 lbs through the intake.......... DUH.
Can someone make this a sticky? this should be laughed at by all.
Hahahha, i've got another 24 pages of this to read when I get home from work.
AE92-5ONIC
Postby .:O4AGTZ:. » Mon Aug 23, 2010 5:28 pm
that makes for 27 pages of awesome reading lol, i have never seen someone ripped apart so badly on a forum and for such good reason
.:O4AGTZ:.
Postby Dell'Orto » Mon Aug 23, 2010 7:24 pm
Haven't you brasso'd it yet?? Maybe give it another jiffing
Postby whynot » Mon Aug 23, 2010 7:45 pm
I've seen that before, good reading. on a serious note I have heard of people putting a small amount of jiff, brasso or autosol into a motor in an attempt to break up the glazing on the bore and get the rings to seal again.
Personally I would only do it out of curiosity on a motor which I didn't care about but more than one person has said it works.
whynot
Postby Truenotch » Mon Aug 23, 2010 10:25 pm
5000rpm blacktop brasso gurgling sounds like a plan!
I've got a bottle that's been sitting around for a while... Never use it because autosol works better for most stuff.
Truenotch
Postby whynot » Mon Aug 23, 2010 11:24 pm
I'm pretty sure they put a few teaspoons of the chosen liquid down the spark plug holes and crank it a bit to spread it around. I wouldnt feed it down the intake as that could result in a valve grind as well, but hey if you don't care then whats the problem?
whynot
Postby CXGPWR » Tue Aug 24, 2010 9:31 am
^ Choice, How bout both for an optimal result? A bit down the spark plugs, crank with the starter for a bit & then start it & down the intake?
Sounds like a plan, Markku bring that around next time your passing & we'll give it a go
CXGPWR
Postby Leon » Tue Aug 24, 2010 9:40 am
I have a recollection of my friend doing the 4000rpm and pouring brake fluid slowly into the carb in a 1000cc Mini.
I don't recall why he was doing it (20 years ago), but the cloud of white smoke out the back was impressive.
He then went on to be a Jaguar specialist mechanic.
Postby Mr Revhead » Tue Aug 24, 2010 9:41 am
So, he was an expert at making cars smoke, then went on to be a Jag expert.... Fitting really :lol:
Postby Leon » Tue Aug 24, 2010 10:19 am
He was an interesting case ... last I heard from him a huge number of years ago he was putting a Fiat twincam into some sort of Mitsubishi rear drive vehicle.
Postby Mr Revhead » Tue Aug 24, 2010 10:30 am
That is an awesome display of insanity! And not the good type! :lol:
Postby whynot » Tue Aug 24, 2010 7:24 pm
that kind of engine swap is, how to put it.. more unusual than the mitsi-lux a friend has.
as for the doses of what to put in I have no idea so I would say start small and work your way up
whynot
