FLESHAXXE wrote:...recently purchased front and rear caliper kit and had them installed... new master cylinder kit...the pedal is getting hard while pumping the brakes
FLESHAXXE wrote:I have checked for leaks at each caliper and elsewhere and have found none....
FLESHAXXE wrote:.the bleeding niples were facing down instead of facing up..
matt dunn wrote:um, would you have noticed that when you bled it?
Users browsing this forum: No registered users and 39 guests
