touge_ae101 wrote:how about raising the mounting points for the suspension arms? haven't got my car here to figure out it if could be possible but could avoid having to deal with the annoying ball joint issue?
perhaps an off-centre mount of some description?
molex wrote:What brand are you current bearings? Importing from the states I assume?
Bazda wrote:molex wrote:What brand are you current bearings? Importing from the states I assume?
Minebea, from Japan.
Trade account at Auckland bearings they are $140+gst.
Thats the only bearing they can get which is Teflon lined and with a 3/4" or 20mm ID bore. With an outer casing thats not too big and able to get the correct angles.
I tried other bearing places but you can only get the normal metal to metal ones which wont do for a ball joint replacement, they would be fine for steering arms though.
Dell'Orto wrote:Bazda wrote:molex wrote:What brand are you current bearings? Importing from the states I assume?
Have you tried Linear bearings? Pretty sure they do teflon lined ones, unsure on costs though.
