Hi guys,
Now I'm no mechanic but know enough about cars to be dangerous.
While my levin is in the shop getting fixed I'm driving around a SSS U12 with an SR20DE. It's recently developed a bad misfire. At first it started off missing every now and then under load at about 2-3000rpm then it quickly got to the point where it was pretty much only running on 3 cylinders. I replaced the spark plugs to no avail, I replaced the dizzy cap, no luck there, there was what looked like rust on the dizzy rotor (i think that's what it's called) so I gave it a very light sand, not sure if that was a good idea or not? feel free to tell me off for doing it lol, anyway that didn't work... then (silly me for not checking) discovered oil in the end of spark plug lead no.1, I had some old leads (not sure if they were good) so I replaced the current leads with the ones i had lying around. Now she runs on all 4 cylinders at idle, however under load she misfires quite a bit. Any idea's on what I can try next?
