Heylin wrote:Ive got a factory cast manifold for 3sgte which is getting some wastegate ports added it it.
Im on a tight budget now with my build coming closer to being finished and was wondering what the best option is for coating the factory manifold
$287 for HP Coatings
or
$20 for 3M Heat Proof Paint rated to 650 deg C
How good are those heat proof paints ? I would think 3M products were pretty good ?.
jayray wrote:I came across this a while ago, they're pretty adamant about not coating or wrapping turbo manifolds
http://www.guy-croft.com/viewtopic.php?f=13&t=759
1I1 wrote:Should see BZR4AGE's FGK extractors where he had them partially wrapped. After an engine bay fire, the manifold is sweet except for the part that was wrapped! It's distorted slightly
Bazda wrote:After time ex wrap will eventually crack your manifold, how long it takes depends on how well they were made in the first place.
Dell'Orto wrote:Bazda wrote:After time ex wrap will eventually crack your manifold, how long it takes depends on how well they were made in the first place.
Must take some years, I've had my Coby extractors wrapped for about 4 or so years now, they havent cracked yet. That said, they're mild steel vs stainless you mind on alot of Jap extractors.
Helious wrote:solid, what's up with that ugly tape ;p ?
Users browsing this forum: Bing [Bot] and 12 guests
