3SGE Cold Idling Issue
Postby xno37 » Fri Sep 10, 2010 5:46 pm
So as of yesterday, I’ve been having a problem where when cold, the car idles very high and changing every second or so between 2200-2500rpm. This only happens until the engine is completely warm, where idle drops to normal 650-700. That’s the only symptom happening.
Engine is gen 3 3sge. I assume a sensor is gone, as everything is still where it should be. What normally/can create this problem?
(EDIT: Took the car to Toyota, problem was idle speed was too high with the ECU trying to lower it. A/C idle up was always on)
xno37
Postby Helious » Fri Sep 10, 2010 6:07 pm
car's "hunting". as it was referred to when i had this issue. was a vacuum leak then i believe, another car it was the TPS.
gl
Helious
Postby sergei » Fri Sep 10, 2010 6:09 pm
or sticky idle control valve.
or air lock in the idle control valve heater circuit (where the engine coolant goes through).
