No clutch pedal pressure
Postby eskimo » Mon Sep 13, 2010 6:51 pm
Hey,
Went to the mountain in the weekend and half way up the road to Turoa I lost all pressure in my clutch, depressed the pedal & there was nothing. I gave the pedal a few more pumps and then managed to get it out of gear, pulled over popped the bonnet to check if I had lost all fluid but it was full.
Tried it again after about 10mins of standing & staring at it and I had a full pedal with loads of pressure. I carried on up the mountain & it did it again 10mins later, pulled over left it for a few mins then the pressure came back.
After leaving Turoa as the weather was poo the pedal was fine all the way back down and during the drive Whakapapa then towards the top of Whakapapa it happens again.
Managed to get to the top left it for a few hours cam back & the car was fine the on drive back to Auckland. Any one know what could cause this... as im baffled
Car is a AE111 corolla GT(20v BT, 6 speed)
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby iOnic » Mon Sep 13, 2010 7:07 pm
Sounds like a bung (or on it's way out) piston seal in the master cylinder causing fluid to bypass the piston
Postby KinLoud » Mon Sep 13, 2010 7:46 pm
I think...
Air bubble in the clutch line, bleed it and it will be ok in the future.
At sea level the bubble is small and gets compressed when you have pushed the pedal a small way.
Up the mountain the pressure is lower and the bubble gets bigger and doesn't get compressed enough to let the fluid push the clutch slave!
Ken
Postby mjrstar » Mon Sep 13, 2010 9:06 pm
^^ yep, needs a bleed.
I ended up with zero clutch pedal in the evo on the way back from taupo, after sitting overnight it had about 1/2 a pedal and it came back to normal after a bleed.
Mine had some milky crappy looking fluid in it so i gave it a dam good flush through.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby sergei » Mon Sep 13, 2010 9:17 pm
Put it this way, if there was a massive leak in the slave cylinder, line or master cylinder seals were completely gone the pedal would not come back up. It would stay down on the floor. It sound like you have an air bubble there.
Postby iOnic » Mon Sep 13, 2010 9:45 pm
Give it a bleed and see how you go. I had a similar problem in my old Starlet. Would have a good pedal if it hadn't been used for a while but after a few gear changes it would lose pressure and turn to shit. Turned out to be the master cylinder.
Postby eskimo » Tue Sep 14, 2010 9:27 am
Cheers guys, Will give it a bleed tonight...
eskimo
Postby tsoob » Tue Sep 14, 2010 10:54 am
iOnic wrote:Sounds like a bung (or on it's way out) piston seal in the master cylinder causing fluid to bypass the piston
my pick as well,
if you bleed and the problem comes back look here..
This happend to me not so long ago
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby sergei » Tue Sep 14, 2010 11:09 am
my pick as well,
They are relatively cheap, but little bit a pain in arse to get to.
Postby 79rolla » Tue Sep 14, 2010 11:27 am
had a similar problem in my ute on the way to Auckland once, wen i used the peddle alot (changing gear going through towns and intersections) it got softer until it did nothing, leave it for a bit and would come back, was the seal's in the slave cylinder, fluid would bypass piston and when left for a while it would go back. after forgetting about it wen i cam to drive home i left my foot on the clutch for a while and all the fluid drained out of the boot... was a fun drive home with no clutch :lol:
slave cylinder was only a yer old too :x
past: AE82 FXGT
79rolla
Users browsing this forum: Bing [Bot] and 19 guests
