Supercharger went *clunk*
Postby ePONYmous » Tue Sep 14, 2010 3:29 pm
Hey, put a 4AGZE in my Mk1 cortina and just started it up today but the supercharger went *clunk* then stopped being a supercharger and started being a nothing at all.
I had the supercharger (SC12) off last week and was spinning it by hand just fine. I was turning it to make sure it hadn't eaten any bolts or such during it's dormancy and it seemed in great shape. So I'm baffled as to why it stopped on me today.
Is there something obvious I should know about the clutch at idle? I wired the Link to turn it on at 1500 so I can idle clean, it should still free-spin below 1500 right?
ePONYmous
Re: Supercharger went *clunk*
Postby sergei » Tue Sep 14, 2010 3:59 pm
ePONYmous wrote:Hey, put a 4AGZE in my Mk1 cortina and just started it up today but the supercharger went *clunk* then stopped being a supercharger and started being a nothing at all.
On the 4AGZE the supercharger is activated by sensing load from map/afm/throttle and not by rpm.
Can you turn it by hand (you can do it by turning the clutch part while the engine is off)?
Postby 85AW20v » Tue Sep 14, 2010 11:22 pm
Could be a nut or bolt was sitting in some other part of the intake and has found its way in....
See ya
Simon
85 MR2 20v
85AW20v
Postby ePONYmous » Wed Sep 15, 2010 9:54 am
sergei wrote:On the 4AGZE the supercharger is activated by sensing load from map/afm/throttle and not by rpm.
Sorry should've mentioned, it's running a Link. The clutch is enabled via a relay and set by RPM in the Link EMS.
85AW20v wrote:Could be a nut or bolt was sitting in some other part of the intake and has found its way in....
Oh Novus! Yea, Im thinking this must be what's happened since a bit of grit it'd eat no worries. That's why I posted because I can't think of anything else that would've made the SC just stop like that other then it eating a lump of metal. If it's irreparably shanked Ima get me an SC14.
ePONYmous
Postby ihavelift » Wed Sep 15, 2010 11:44 am
ePONYmous wrote:If it's irreparably shanked Ima get me an SC14.
get. an. sc14.
Current: 2000 Honda Accord Wagon CF6
Previous: 97 Toyota Celica GT4 ST205; 2001 Toyota Allex RS180, 96 Nissan Sentra SG
Low, Slow, Clean and Mean
ihavelift
Postby Adamal » Wed Sep 15, 2010 1:25 pm
An SC14 will need a bit of custom work, doesn't bolt straight up.
Postby Skin » Wed Sep 15, 2010 2:02 pm
good excuse to just go turbo :D
cogent wrote:iPhones can eat a dick.
1981 Mazda RX7
1997 Toyota Corolla
Skin
Postby ePONYmous » Wed Sep 15, 2010 6:11 pm
There's a bit of alloy that mounts onto the SC which you plumb to the IC. It's held on to the SC by 5 bolts. If any of those bolts are too long they stop the SC blades from turning.
Also, the large rag stuffed in the IC pipe wasn't helping
:roll:
ePONYmous
Users browsing this forum: Google [Bot] and 25 guests
