fanbelt for 1jzgte when removed aircon pump
Postby drift-monkey » Tue Sep 14, 2010 4:38 pm
Had a search for it, ive found the thread before but i cant find it now, has anyone got the part number for the fanbelt you use on 1jz after you have removed the aircon pump! Cheers!
drift-monkey
Postby MrOizo » Tue Sep 14, 2010 6:28 pm
Its 40mm shorter than stock so is (i think) 6PK1600
MrOizo
Toyspeed Legend
Postby thegreatestben » Tue Sep 14, 2010 9:43 pm
factory belt is indeed a 6pk1940, 1jzge is 6pk1960
Last edited by thegreatestben on Wed Sep 15, 2010 1:05 pm, edited 1 time in total.
thegreatestben
Postby the fallen303 » Wed Sep 15, 2010 10:40 am
gates code is K060735, other code is 6PK1865.
true house of JZ
Stay true to the origin
the fallen303
Postby DFECTED » Wed Sep 15, 2010 10:25 pm
i used the std one, just bent the powersteer bracket a bit and changed the bolt hole in the block
DFECTED
Users browsing this forum: Bing [Bot] and 22 guests
