Now my main question is, if cams are designed for one head setup (eg gen 2) are they able to be used in a later one? (gen 3). It looks like the cams were used/to be used in a GTT head, can i use them in my gen 3?
frost wrote:yes
i dont think you can use st215 cams in your st205 motor, because i think the intake cam is slightly shorter where the sensor trigger arm is bolted on, so you wont have enough meat to cut for the dizzy slot.
i might be wrong but best to check as i remember telling a friend it looked shorter.
go to this page, scroll down to the pics of the cams in a st215 and you can see the trigger arm,
http://www.alltrac.net/phpBB2/viewtopic ... 4d9c4f898a
are these second hand cams cheap? because your prob better off with the HKS 264 cams, they give the best power up throughout the rev range without loosing out anywhere,
frost wrote:oh from gen2 then its sweet, you said gtt and i thought gtt caldina,
Users browsing this forum: Google [Bot] and 26 guests
