small breather filter Q
Postby touge_ae101 » Wed Sep 22, 2010 10:23 am
so after a thrashing at the track my breather filter was spewing out a bit of oil. at present it just breathes to atmo but i am making a catch can soon!
so now my filter is full of oil is there any way of cleaning them out/removing oil??? cause when you blow through it there is quite a bit of restriction so i'm sure it can't be doing much breathing!
have got another filter on there now and i realise these filters are cheap but its more the hassle so would rather these filters not be throw-away items.
p.s. i hope everyone got the thread title. :lol:
touge_ae101
Postby Flannelman » Wed Sep 22, 2010 12:36 pm
Ive cleaned filters with a bit of meths. Or any degreaser.
Unless its a paper one...?
Flannelman
formerly known as Affroman
Postby Heylin » Wed Sep 22, 2010 1:28 pm
Simple green and hot water works well also, ive been cleaning my pod for years using this method.
Heylin
Heylin
Postby touge_ae101 » Wed Sep 22, 2010 1:29 pm
cheers guys will give it a bit of an experiment this arvo.
i'm not sure it might be a paper one its just a cheap simota one so nothing special. lol
touge_ae101
Re: small breather filter Q
Postby allencr » Wed Sep 22, 2010 1:44 pm
touge_ae101 wrote: would rather these filters not be throw-away items.
Throw it away, it does nothing, it filters nothing, it will only keep bugs from crawling in or accumulate oil - that's it!
The engine needs to vent blowby, either to the atmosphere or the intake, you may use a puke/catch can between the engine and whatever final destination you've choosen. :)
allencr
Postby touge_ae101 » Wed Sep 22, 2010 3:22 pm
thats the idea of making a catch can hopefully by the end of the week. :D to stop the blow by from spewing oil into my filter and eliminate and oil entering the intake through the PCV valve. 8)
touge_ae101
Postby Heylin » Thu Sep 23, 2010 9:24 am
i use the following setup and it works well
pcv valve to catch can to inline fuel filter to intake
apparently the vacuum off the intake assists in pulling the gases out, i dont get any oil in the intake
Heylin
Heylin
Postby strx7 » Thu Sep 23, 2010 11:25 am
touge_ae101 wrote:thats the idea of making a catch can hopefully by the end of the week. :D
Make sure it is large enough in relation the your engine's capacity, as set out in Schedule A
Postby touge_ae101 » Thu Sep 23, 2010 12:03 pm
yeah its only a 4age so 1L :lol: :lol:
touge_ae101
Postby matt dunn » Thu Sep 23, 2010 11:05 pm
And usually the idea on a catch can is not to stop oil from getting into the intake,
but to stop oil vapours entering the intake,
as oil vapour causes detonation,
which the knock sensor usually picks up and drop's timing to compensate.
Postby touge_ae101 » Fri Sep 24, 2010 12:53 am
matt dunn wrote:And usually the idea on a catch can is not to stop oil from getting into the intake,
yes oil in the form of vapour is what i meant. :roll:
touge_ae101
