nile wrote:...So I checked that all 4 plugs were sparking and they weren't ...
nile wrote:...Plugs look fine when I pull them out, and they spark heaps...
nile wrote: so I got the distributor cap, leads, and plugs from another working big port and put them on
nile wrote:I just put them into my other motor and that still runs fine, could the plugs still be bad? They are only about 1,000kms old.
l1ttle_d3vil wrote:The plugs can foul up in a matter of minutes depending on what they are, if you have access to an air gun blow the crap out of them to make sure all the cleaner is evaporated and chuck them back in dry, don't spray engine start on them or anything.
I use brake clean to clean mine - spray it on and let it sit for a bit, wipe them down with a rag, spray some more on and wipe it down again before blowing them out with the airgun. If I don't dry them out properly before putting them back in it still has trouble starting sometimes and won't idle properly for the first 10 - 15 seconds unless I give it a bit of gas.
Lloyd wrote:Are the plugs actually coming out wet or what? Fuel, Air, Compression, Timing, Spark. Got those then it should run. Which one is missing?
Lloyd wrote:Is it even firing or just cranking? Can you see if the spark timing is correct on the crank pulley when cranking with the timing light or not?
If its getting too much fuel (ie dodgy water temp sensor) then it could be flooding quite easily and not starting due to too much fuel also.
