Also halfway between the last line and the second last line the reserve light goes on
coolnik12 wrote:Hey guys i own a 1996 Trueno and i have been noticing that when i fill up fuel in my car, it takes pretty long for the needle to actually come up to the right level
metal_sean_head wrote:coolnik12 wrote:Hey guys i own a 1996 Trueno and i have been noticing that when i fill up fuel in my car, it takes pretty long for the needle to actually come up to the right level
I think this is normal. This is what my FX does.
How many kms are you getting to a tank?
touge_ae101 wrote:depends on a lot of things really though.
- have you got fresh spark plugs?
- have you cleaned your throttle bodies recently?
- have you replaced oxygen sensor?
- have you checked timing?
mine does (did) about the same km's on the open road and that was 20degrees advanced timing so hopefully i'll get a bit more out of it now
h8wrxs wrote:mm my both truenos ive had , (and gtz levin actually) have done around 300km in top half then only about 100-150km on the bottom half of the gauge
eskimo wrote:I get 450 to a tank around town(auckland traffic 5 days a week) 300kms to the first half and 150 to the second half. Thats running BP98 in my AE111
I replaced my oxy sensor with a TGP one about 6months ago as I was only getting 360-80kms to a tank so it is worth replacing
