Brake master cylinder too small for brakes?
Postby Quint » Thu Sep 23, 2010 8:29 pm
Took the supra for a test drive finally. Brakes work barely.
I'm guessing the standard GA-70 brake master cylinder is too small to drive the JZA-70 pots i've put in (new hubs etc.)?
Cheers.
'Ohh, she goes quite well.'
'Ah oh, they don't.'
Quint
Postby RomanV » Fri Sep 24, 2010 11:51 am
You can get the standard master cyl bored out to a larger diameter, which makes it pump more fluid through.
Or find a master cyl with a factory larger bore that bolts to your booster, IIRC V6 camrys have got a fairly large dia bore in the master cyl.
Postby rollaholic » Fri Sep 24, 2010 12:29 pm
whats the brake pedal doing?
Postby Quint » Fri Sep 24, 2010 12:41 pm
Travelling to the floor and then feeling very soft when the brakes start to engage.
Quint
Postby Malcolm » Fri Sep 24, 2010 1:12 pm
lots of travel and feeling soft could certainly mean the master cylinder is too small a diameter, but it could also be that your brakes are not properly bled. I'd suggest giving them another good bleeding before looking to solve a problem that may not exist. It may still be prudent to increase the size of your master cylinder if you have increased your piston area though
Postby rollaholic » Fri Sep 24, 2010 1:38 pm
if you give the pedal a couple of pumps it should tell you whats going on, if you start to get a better pedal after a few pumps then you most likely have some air in there.
Postby allencr » Fri Sep 24, 2010 1:52 pm
Quint wrote:Travelling to the floor and then feeling very soft when the brakes start to engage.
Air and/or bad MC.
While a small dia. MC will feel a bit softer from its different mechanical/hydraulic advantage, you couldn't say that it feels very soft from that alone and it would not got to the floor, just about 2cm/1in travel difference.
allencr
Postby Quint » Sat Sep 25, 2010 6:34 pm
Pots are the same size between the two, so that isn't the problem.
Bleed the callipers, no air there, noticed however that the air is bubbling up in the Master cyl. Continuous pumping, continuous air bubbles. If air is leaving the system (bubbles in the master cylinder) Then how is the pedal not coming up? Tryed to undo the line closer to the cylinder to bleed it there, but toyota never intended them to be undone (brass starts to strip)
Has me scratching my head.
Quint
Postby Flannelman » Sun Sep 26, 2010 5:58 pm
Sounds like the master cylinder is poked. replace it and your brakes shall return.
Side note - to check if the booster is working have the engine off and pump the brakes till they are hard. Press on the pedal and start the engine. The brake pedal should sink if the booster is working.
Flannelman
formerly known as Affroman
Users browsing this forum: Bing [Bot] and 19 guests
