I was given a strut brace for my ae92. I was told it was from a levin but I'm not sure which model. The holes on the brace match up but are around 10mm to far apart (strut brace is to long by 10mm). Two questions
What vehicle is this strut brace from?
If I slot the holes on the end brackets so the middle bar can move 5mm at each end. Will the brace still work? The towers will be restricted in there movement inwards toward each other but not outwards away from each other.
