Give me some ideas
Postby Mr Revhead » Sat Oct 02, 2010 10:29 am
Hyundai have stepped up... i would now rate them alongside the upper Jappas.
We will be getting a coupla of their new vans. 6 year 1000,000km warranty 8O
Postby iOnic » Sat Oct 02, 2010 11:05 am
Mr Revhead wrote:We will be getting a coupla of their new vans. 6 year 1000,000km warranty 8O
If ever there was an incentive to buy a car - that's it 8O
Postby S T E A L T H » Sun Oct 03, 2010 2:55 pm
did I read that right? A MILLION km warranty?
Covering everything with no excess on claims?
-2010 Toyota Landcruiser VX
S T E A L T H
Postby Mr Revhead » Sun Oct 03, 2010 2:58 pm
Yes. 6 year one million kilometers
I have asked what the catch is, the boss is yet to find one...
They will also cover your trailer. If a fault causes loss or damage to your trailer and/or its contents. They will cover that too.
They also say they don't even need to do the servicing. As long as the services are done and shown to be done then it's fine.
Postby wde_bdy » Sun Oct 03, 2010 7:25 pm
The usual clause is it does not apply to vehicles used for commercial purposes so couriers and taxis (the only ones who will ever do that sort of mileage) are excluded. Would be very very interested to see the fine print on that warranty.
Callum
wde_bdy
Postby Mr Revhead » Sun Oct 03, 2010 7:49 pm
As would I, I can't believe there is not a catch
Postby wde_bdy » Sun Oct 03, 2010 8:08 pm
I just checked the Hyundai site, only thing it mentions is extended warranties for an extra 3 years (on top of standard 3 years, 100,000 k's) with unlimited k's. Also says "Covers any part, manufactured or supplied by Hyundai, if found to be faulty in material or workmanship - under normal use and maintenance", which gives them an out under expected lifespan. Pretty much any part on a car could be argued to only have a lifespan of 200,000k's max before needing replacement. You need to prove there was a fault in the materials or workmanship before they would pay on anything.
Callum
wde_bdy
Postby frost » Sun Oct 03, 2010 10:32 pm
after owning the bmw 745i for a year i must say its a great car,
best feature about the car is the computer, it tells you when things need fixing or looked at before it becomes a major problem.
e.g
(warning rear brake pads down to 25%)
so you service it before the brake sensor is chewed and only pay for pads and disc machining. less the cost of the sensor at $160ea.
in a jappa you only know to service the pads when the sensor is chewed out, so you pay for sensor, pads, disc machine.
automatic switch off of all electrical equipment when battery is low, so you never get caught out with a flat batt.
in a jappa the lights stay on till the batt is dead:(
i think buying the flagship car of a manufacturer is a good idea, more care in design and manufacture. i plan on buying bmw7 again,
Postby Alex B » Sun Oct 03, 2010 10:41 pm
Most euro disks are not skimable and need done a fark load more often than jappa ones. Its really not hard to look and see if you need a replacement set of pads.
Postby rollaholic » Mon Oct 04, 2010 7:43 am
i like the old fashioned warning myself, squeal indicator on the pads
yuck 7 series :P
Postby wde_bdy » Mon Oct 04, 2010 8:42 am
frost wrote:automatic switch off of all electrical equipment when battery is low, so you never get caught out with a flat batt.
Wow that is great, all my jappa does is buzz to tell me if I have left the lights on or left the keys in the ignition. Far too simple though isn't it?
:lol:
wde_bdy
Postby Al » Mon Oct 04, 2010 10:49 am
Isn't that what most cars have done since the early '90s? The MR2 used to, the Vectra used to have this horrid loud screech and even the Renault's warning still works!
Al
Postby metal_sean_head » Mon Oct 04, 2010 10:52 am
Al wrote:Isn't that what most cars have done since the early '90s? The MR2 used to, the Vectra used to have this horrid loud screech and even the Renault's warning still works!
Late 80's even.
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby iOnic » Mon Oct 04, 2010 10:53 am
Yeah most cars have done that since the 80's (warning you of lights on/key in ignition). Never heard of most Euro disks being impossible to skim or needing to be done more often except in the UK. AFAIK They're no different to any other disks but we're all here to learn...
Postby sergei » Mon Oct 04, 2010 11:33 am
iOnic wrote:Yeah most cars have done that since the 80's (warning you of lights on/key in ignition). Never heard of most Euro disks being impossible to skim or needing to be done more often except in the UK. AFAIK They're no different to any other disks but we're all here to learn...
Disks aren't different, but pads are.
Postby iOnic » Mon Oct 04, 2010 12:13 pm
Yeah I know pads are different but...
Alex B wrote:Most euro disks are not skimable and need done a fark load more often than jappa ones.
Postby sergei » Mon Oct 04, 2010 12:34 pm
iOnic wrote:Yeah I know pads are different but...
Because pads chew through rotors at much quicker rate?
Postby Mr Revhead » Mon Oct 04, 2010 12:34 pm
Is true.
Lexus have been like it for a while now too.
Discs needing changing evey 1-2 services. thats 15-30ks
Postby iOnic » Mon Oct 04, 2010 12:41 pm
Something else to look out for at work :lol: Which models does that apply to? We normally only replace the discs when they're below minimum thickness which seems to be around the 40-60,000kms mark depending on how the car is used.
EDIT: Should also mention that the SW20 manual recommends inspection/replacement of the discs every 12,000kms or 1 year so replacement every 30,000kms/2-3 years is nothing out of the norm really.
Postby Brawler » Mon Oct 04, 2010 1:49 pm
Buy a 3sge vvti 6 speed altezza, Great cars! Lots of aftermarket parts too!
zing! Sig got nuked. Sorry bout that.
Brawler
