T-series Torsen LSD?
Postby Hachiroku » Thu Oct 07, 2010 3:25 pm
I see this guy is advertising a T-series diff head with a torsen LSD. I wasn't aware that such a thing existed. He's adamant that it's T-series and not F. Any idea what LSD unit he might have used / modded to fit?
http://www.trademe.co.nz/Trade-Me-Motor ... 840530.htm
Hachiroku
Postby ryanfels » Thu Oct 07, 2010 3:43 pm
T series torsens come out of rear end of celica ST205 GT4s i believe
thegreatestben wrote:It's lucky you arent a douchebag other wise I wouldn't help you :wink: :wink:
mark 2 gx61 2jzgte powered - viewtopic.php?t=72619&start=0
Discussion - viewtopic.php?t=72620
ryanfels
Postby Prymal » Thu Oct 07, 2010 6:19 pm
All widebody St185's RC's and aus spec 185's from knowoelege also came with the torsen , as well as the 205..
No ones ever claimed 100% as far as i know that the Gt4's run a t series , but it would be handy to know!
St205 NZ New Group A WRC Gt4- Accept no Imitations !
Prymal
Postby Rob_GTZ » Thu Oct 07, 2010 6:22 pm
Also GTT Caldina wagons. I don't believe they're actually considered a T series, but they are indeed 6.7" & will accept the T series Crownwheel with no mods. Did this conversion in my AA63 Carina, worked out ok, but certainly no comparison to decent 2 way LSD
Rob_GTZ
Postby Hachiroku » Thu Oct 07, 2010 6:39 pm
Any idea if it could be used in a live-axle drum brake T-series eg AA60, TT141?
Hachiroku
Postby Rob_GTZ » Thu Oct 07, 2010 7:08 pm
Would need to find axles to suit. Early T Series are too small, may be the same as late T series, but i'm not 100% sure.
Mine was IRS, so just used the original Stub axles & redrilled the flanges to mate them to T Series Carina Outer shafts
Rob_GTZ
Postby Brawler » Thu Oct 07, 2010 8:10 pm
I was thinking about doing this for my t series diff, but at the end of the day from what ive read they are just not as strong as the F series ones. I am just gonna end up swapping out my whole subframe for an F series.
But If its true that you can fit the LSD internals off the celica GT4s or caldina with no mods, Just buy one of the diffs from one of those cars, Ive seen LSD ones go for $100-$150
zing! Sig got nuked. Sorry bout that.
Brawler
Postby wde_bdy » Thu Oct 07, 2010 8:56 pm
Yeah, but you might as well swap to F series and then run an Altezza torsen.
Callum
wde_bdy
Postby Brawler » Fri Oct 08, 2010 5:26 pm
wde_bdy wrote:Yeah, but you might as well swap to F series and then run an Altezza torsen.
Callum
What mods do you need to do to fit the altezza internals in?
Brawler
Postby wde_bdy » Fri Oct 08, 2010 8:05 pm
A bit of bearing swapping from memory, Im sure there are details posted in the Toymods forum.
Callum
wde_bdy
