sergei wrote:The centre is a viscous.
You cannot adjust it anyway.
It is 50:50.
iOnic wrote:Pretty sure they're a sealed unit with silicone oil and not really serviceable?
strx7 wrote:the naming on those parts isn't actually correct, what is labeled as the 'centre diff' is actually the front diff as the side gears etc inside that diff are the ones which drive and allow slip to both front axles.
what is listed is the 'transfer' is technically part of the centre differential which also houses the viscous coupling. the small shaft at the RH end of the viscous coupling goes right thru the centre of the VC and gives drive to the RF axle.
cat007 wrote:strx7 wrote:the naming on those parts isn't actually correct, what is labeled as the 'centre diff' is actually the front diff as the side gears etc inside that diff are the ones which drive and allow slip to both front axles.
So the part that actually controls the 50:50 split between front and back....how can you make that work betterer?
Dell'Orto wrote:I read the thread title as Center diff in ST215 welding? and I think its the best option tbh
strx7 wrote:the viscous coupling is what controls the torque split between the front and rear wheels. If you launch any of the modern 4wd cars with east/west layout, and even wrx's (without adjustable DCCD) have front bias, and if you launch you will get front wheel spin unless they have a locked centre diff
you cant really adjust the split
