certs.
certs.
Postby blindnz » Fri Oct 15, 2010 10:10 am
Whats the deal with certs? im looking at a ae92 fx 4 door thats had a BT transplant. Still has drum rear, will i need to swap to fxgt front and rear brakes? What sort of other things would it be likely to need for cert?
blindnz
Postby tsoob » Fri Oct 15, 2010 10:13 am
http://lowvolumevehicle.co.nz/
post it up on here, john will set you right
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby touge_ae101 » Fri Oct 15, 2010 10:43 am
swap over some decent brakes from a newer fxgt or levin and you should be able to get away with it. technically its a bit of a grey area but there has got plenty of 20V's in ae92's that get warrants fine without a cert.
but i would suggest changing drums for piece of mind. also look at twinpot fronts :)
touge_ae101
Postby Rob_GTZ » Fri Oct 15, 2010 3:37 pm
While certainly not ideal, the standard brakes should be fine for cert, as long as they're in good order. I would probably just recommend giving them a decent check over. Brake fluid change & new pads wouldn't hurt either.
Nothing wrong with Drum brakes, no real need to change them if they're in good shape
Rob_GTZ
Postby Leon » Fri Oct 15, 2010 5:53 pm
You need a cert.
If you're talking a four door "FX" I'm guessing 5A power 1500cc ... now you're 1600cc and plenty more power.
No cert and a crash means your insurance is fuxxored if you want to claim on it. Means your WOF isn't worth the paper it is written on. If you get pulled over in a boy racer raid, there's a good chance you might get done.
Ditto your car being built with drums, and changing to discs.
Doesn't matter a damn what other cars made by Toyota came out with. What did *your* car sitting in front of you, with that specific chassis # come out with ...
Having all the factory parts available in another damn near identical Toyota should mean you can bolt on everything with no fabrication, and cert will be walk in the park.
Postby Bling » Fri Oct 15, 2010 9:15 pm
I think he's just asking if he will need discs over drums for cert, not if he needs cert :)
As for the braking, most is biased to the front, so good pads up front should help towards a cert. I wouldn't swap out the drums unless you plan to give it a hard time / track time as they should do fine. Weight wise the car will be about the same as factory, so if they worked fine standard, they will still work fine with a blacktop.
Postby levinguy » Fri Oct 15, 2010 9:24 pm
don't they just do a road test for the brakes?
it has to stop 3 or 5 times from 100kph within a certain time frame, depends on whats been done. without getting any noticeable fade or anything else going wrong.
its in the lvv code??
easy enough to test out yourself
levinguy
Postby Leon » Fri Oct 15, 2010 9:53 pm
BZG|Bling wrote:I think he's just asking if he will need discs over drums for cert, not if he needs cert :)
There were signs that the conversation was heading into the very familiar territory of misinformation, so I thought I'd put my pedantic 2c worth in :lol:
Postby blindnz » Sat Oct 16, 2010 9:17 am
i would always get the cert, if i wasnt to have a cert i may aswell not have wof and reg :P.
Yeah it was a 5af, i was just wondering how hard it is to get, and what sort of work i would need to do to get one.
blindnz
Postby DexGT » Sat Oct 16, 2010 9:56 am
levinguy wrote:don't they just do a road test for the brakes?
This was the case when I got my cert , so as said as long as your brakes are in good nick , then you should be fine.
Having said that, upgrading the front brakes to what a GT runs isn't a silly idea , and if you do it after you cert the motor , you then need to get the car re-certed .
So do everything you want to do , then cert it 8)
DexGT
Postby Leon » Sat Oct 16, 2010 11:44 am
blindnz wrote:i would always get the cert, if i wasnt to have a cert i may aswell not have wof and reg :P.
Saves a lot of grief [thumbs up]
