whynot wrote:I would have thought the fuel bowl breathers would need to see positive pressure from the turbo otherwise the fuel will be getting pushed back into the bowl from the jets.
whynot wrote:there should still be a pressure difference between the intake and the venturi
Lloyd wrote:whynot wrote:there should still be a pressure difference between the intake and the venturi
So why does a car need 3psi fuel pressure then instead of 0psi even though there is a vacuum present?
Getting around it with car carbs involved running restricters before the carb and venting the bowls to above those
You obviously dont know how a Carb works
Lloyd wrote:Sorry, was basically just trying to imply that the pressure in the carb needs to still be over what is in the intake.
Lloyd wrote:Anyway, point is you need to keep the fuel pressure a few psi over what you're getting in the inlet manifold
