What nut?
What nut?
Postby TRD_ZERO » Tue Oct 26, 2010 12:18 pm
What size nut do i weld onto my exhaust for a oxygen sensor? For tuning purposes only.
Previous:
TRD_ZERO
Postby touge_ae101 » Tue Oct 26, 2010 12:20 pm
get the oxygen sensor and measure it? if you are using it for tuning you will need a wideband oxy sensor which sometimes come in diff sizes anyway.
touge_ae101
Postby Malcolm » Tue Oct 26, 2010 12:59 pm
The standard size is M18x1.5
Postby strx7 » Tue Oct 26, 2010 2:40 pm
Malcolm wrote:The standard size is M18x1.5
yip, same as spark plug thread (cause they come in handy for blocking the hole when not being used)
Postby Malcolm » Tue Oct 26, 2010 3:03 pm
and making flamethrowers. Wouldn't think you'd see many modern engines with those big 'ol sparkplugs in them though, I'd think most would be the smaller (m14?) plugs.
