swapping wheel centers
Postby hsmidy » Mon Nov 01, 2010 10:21 am
Hey
so im trying to get myself a set of ssr longchamp rims but having trubble finding them in the correct width.
so i thought maybe if i get another set of ssr rims in the same diameter would i be able to just swap the centers over or are the two outers different between wheels.
hope that made sence
hsmidy
Postby tsoob » Mon Nov 01, 2010 3:57 pm
its possible, give rodney a call at brugar engineering
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby B_giB » Mon Nov 01, 2010 4:09 pm
+1 for Brugar.
Excellent engineers there.
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby Bling » Mon Nov 01, 2010 4:39 pm
Yeah in Auckland... :? unless the OP's location is wrong, that won't be much use.
Mixing and matching of wheels is doable, so long as the centres match the outers. Bolt spacing etc. People have used two inner sections to create some stupidly wide wheels. If that's what your asking anyway?
Postby hsmidy » Mon Nov 01, 2010 5:28 pm
more just trying to get the wheel centers on to a more readily avalible wide wheel
hsmidy
Postby coupekiwi » Mon Nov 01, 2010 5:32 pm
Pretty sure Champs are welded from the factory.
The bolts are for aesthetics.
In saying this you can cut them open but unless you want a 10j wheel you will need to buy wheels that are wider anyway so you may as well just run them.
Any old Japanese wheels are worth too much now.
coupekiwi
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
