whats it worth?
whats it worth?
Postby NOLAW » Tue Nov 02, 2010 2:32 pm
A guys wanting to buy my link g3 ecu and loom suited to run a 4agte, whats it worth as im unsure of what i shouild be asking for it, its still in as new condition as its had very little use (hours), what would you guys say its worth?
NOLAW
Postby levinguy » Tue Nov 02, 2010 2:34 pm
i'll give you 600 for it :D
levinguy
Postby JustinSpiderholden » Tue Nov 02, 2010 2:35 pm
1000 Bucks
The new g4s are pricey and the Atoms don't compare to the G3
Why are you going to replace it?
JustinSpiderholden
Postby NOLAW » Tue Nov 02, 2010 3:00 pm
was going to consider upgrading to a g4 as im upgrading the engine setup and going 7agte, if i cant get much for the g3 though to fund towards the g4 (as il also have to get it wired in aswell) then i might just stay with the g3..
NOLAW
Postby levinguy » Tue Nov 02, 2010 3:06 pm
just upgrade the g3 to the g4 software..
levinguy
Postby NOLAW » Tue Nov 02, 2010 3:12 pm
yeah iv had that mentioned to me..how do i go about doin that, sounds alot cheaper
NOLAW
Postby levinguy » Tue Nov 02, 2010 3:55 pm
ring link, you need to send it down to them,or one of their dealers may be able to sort it out. it doesnt cost much, maybe 180 but i can't remember 100%
thats what i'd do, its almost effectively the same thing, just without the same amount of inputs/outputs
levinguy
Postby QikStarlie » Tue Nov 02, 2010 7:16 pm
was $220 when i done mine. you pay your money and give them serial number, they send you a 4 number code and you update yourself like a normal firmware update.
it will mess everything up on the computer. basically have to set it up from scratch, wouldnt advise doing it if your car is already tuned
g4 software is better and you can do alot more with it. but if you haven't got anything fancy to run. may as well stick with g3 firmware
QikStarlie
Postby NOLAW » Tue Nov 02, 2010 7:26 pm
il probly have to get a few adjusments done anyway to suit the new setup, and as for fancy stuff i have a few things up the sleeve :wink:
NOLAW
Postby l1ttle_d3vil » Thu Nov 04, 2010 8:50 am
NOLAW wrote:il probly have to get a few adjusments done anyway to suit the new setup, and as for fancy stuff i have a few things up the sleeve :wink:
G3 is perfectly capable of running NOS....
:wink:
