I'm running BAZDA ISC coil overs allround with factory front and rear swaybars.
Do i need a harder front bar? or a harder rear bar? or do i need harder front spring rates???
As most factory vehicles are biased towards understeer, fitting of the larger rear swaybar will help in providing a more neutral characteristic in the handling at the limit. This is due to the increase in roll stiffness at the rear, which loads the rear wheels more unevenly and provides slightly less grip at the rear than previous.
At first this may sound sacrificial, however, as the rear end is resisting more of the roll, the front end resists less in proportion, leaving the front wheels more evenly loaded, therefore more available front end grip. In the end an increase in overall grip can be achieved by balancing the vehicle. A WRX or other front torque biased all wheel drive vehicle will benefit even more due to combined front end steering/traction demand.
Truenotch wrote:but it sounds like this might need more than just a bar.
edwagon wrote:Torsen diffs need both wheels on the ground to work properly.
If that inside wheel lifts, or gets very light, the Torsen will not act as an LSD.
