YeMs wrote:shorten the shocks the amount that u want to lower it? (as long as its not a huge amount so as to not create to much pre-load)
sik_gt_starly wrote:get some fat friends, problem solved and wont have to spend a cent
Looonie wrote:Cutting springs is better than compressing them IMO.
I recommend cutting at the top of the spring rather than the bottom as usually the bottom coils taper to meet the lower spring seat, but your suspension may be different.
So long as the shocks are shortened to keep the springs captive, IMO cut springs are the third best option after height and rate specified lowering springs with matched shocks or coilovers...
Most generic lowering springs don't do much with the spring rate to cater, and are often progressive so as to keep a nice comfy ride until you work through the corners.
tsoob wrote:I can't believe you guys answer a 'tech question' with cutting springs. The spring has a load rate that it has been designed to take using all of its coils.
If you are unhappy with the ride height AND you don't have the cash for coilovers (which are soooo cheap these days)
Best option is to have the springs compressed by a professional I'd reccomend Snell springs in Onehunga or Cobra in the south island, and then shorten the shock to suit.
VR-4Squid wrote:You can quite easily work out how much difference it will make to the spring rate also.
http://speedhero.wordpress.com/2010/10/23/cutting-springs-the-guide/
They would know how...? Providing you do it properly and put a bit of paint where you cut it.Heylin wrote:If you want a small drop in ride height, and a small increase in spring rate, cutting half or one coil off the spring is fine provided it's still captive.
do the LTSA agree with that ?
Users browsing this forum: Bing [Bot], Google [Bot] and 20 guests
