CAMB01 wrote:Cages must be welded in, no bolt in cages are legal as far as i know, even for WOF purposes.
CAMB01 wrote:A full rollcage requires homologation to MSNZ, a LVV MSNZ authority card and a competition vehicle logbook, also race seats and harnesses must be fitted.
A minimum of 2 events a year is required to keep the authority card current. (Authority card is required for warrant of fitness).
Thats the basics of it.
Leon wrote:You can have a bolt in half cage or a welded in half cage. You can then go through either LVV or MSNZ.
stalker wrote:Leon wrote:You can have a bolt in half cage or a welded in half cage. You can then go through either LVV or MSNZ.
so does that mean that you can put in a bolt in half cage, and as long as its LVV cert'd you can get wof's without issues?
