Bomis wrote:Only complaint most ppl have is how loud the motors are, not sure if thats an issue with the newer ones. I have a 2002 as a work ute, never had any probs with it really.
GDII wrote:My Dad has a 2004 Flat deck 3.0 4WD. The front mount intercooler cracked so it had an epic boost leak. Was a common problem for that model. Also somehow the fuel pickup mounting rods bent almost 45 degrees inside the fuel tank. These were 2 8mm stainless steel rods. Not sure how it happened as the fuel tank hadn't been hit.
It had epic turbo lag but it think the new model has a different engine now. Apart from that it would pull really well at speed and when in 4WD it was great on gravel roads. So much grip for a large vehicle. It's really good at hauling around 1 ton of sugar.
Burning Angel wrote:GDII wrote:My Dad has a 2004 Flat deck 3.0 4WD. The front mount intercooler cracked so it had an epic boost leak. Was a common problem for that model. Also somehow the fuel pickup mounting rods bent almost 45 degrees inside the fuel tank. These were 2 8mm stainless steel rods. Not sure how it happened as the fuel tank hadn't been hit.
was driving it in the weekend, going up to wanaka into the wind i had my foot flat in 5th to go 100km/h, he really needs to get a new common rail one 'cuz I'm used to driving the hiluxs at work which go bloody well(had a wee bit of sustained loss of traction outside the stadium today )
reliable but gutless down low, but utes are for practicality, not performance
