Letting it sit for 5 or so mins seemed allow us to go for a few kays before dying.
iOnic wrote:Had a friend with an SP20 that had almost exactly the same symptoms and it turned out to be a bung AFM. Apparently a common fault on them.
but thisLetting it sit for 5 or so mins seemed allow us to go for a few kays before dying.
sounds to me like overheating coil[s]. next time it does it put your hand on the coils and check how hot they are. Should be warm to the touch but not hot.
Re: coils - I can't conculsively say waiting helped (I only tried stopping the car and restarting twice before deciding to let everything cool down).
85AW20v wrote:Blocked breather to the fuel tank? When you stop it allows air in again. Try running with the fuel cap off. Or maybe blocked fuel filter.
I found putting a tiny bit of load seemed to keep the car going. No load it would die. Too much load it would miss & die.
Nuty|Mike wrote:step mums same model 323 was having similar problems after changing temp sensor and other expensive things it turned out to be a small split in the intake hose,
Could be a good thing to check first ?
touge_ae101 wrote:my sister in laws exact same car had exactly the same problem!i told her to look at the afm but turned out the battery was just dead. like properly dead. seemed weird but went sweet after a new one.
