gmacrae wrote:my silvertop runs a blacktop ecu - goes heaps better too, little bit flat below 2000 rpm but better overall.
Dragger_Dan wrote:gmacrae wrote:my silvertop runs a blacktop ecu - goes heaps better too, little bit flat below 2000 rpm but better overall.
Where have you connected your MAP sensor to the silvertop intake? I'm not sure I've got mine right as it seems to run a bit rich, leaves a bit of a cloud behind it over 6000rpm.
FLESHAXXE wrote:I have tapped into the line that goes to the fuel pressure regulator...I find the car to be running a bit rich as well......
