BZG|Bling wrote:It didn't come with any other parts? Generic type gear knobs usually come with fitting kits that use allen keys to fit it to your gear stick. Hard to say though without seeing what you got.
gasman wrote:a good mechanic should have a tap and die set lying around for when he strips a thread like i do.
costs about 100 bucks for a pretty comprehensive kit, so it might be worth getting one your self.
to link pictures directly use the "Img" tags when you reply.
BZG|Bling wrote:Fixed the link for you, but the image is way too big. Plus we already know what a gear stick looks like, what the gear knob looks like is what we need. But if it didn't come with any other parts and isn't threaded already then that's strange.
When linking to images, make sure they are say 800x600 pixels in size, and make sure you're linking to the image itself. Right clicking the image and copying the image url usually works, then paste that between [img].....[/img] tags
Emperor wrote:Does it not just screw in to the plastic?
Subarus gearknobs have the same insides, the plastic inside the knob just threads onto the gear shifter with a bit of force...
If not, just like everyone else said, go borrow an M10 tap and it should screw on easy.
If the inside of the knobs to big, then you could possibly glue a 10mm riv nut inside the knob.
BZG|Bling wrote:You sure it won't screw on? It would need to be a tight fit otherwise it would not grip to the thread
BZG|Bling wrote:If its the same as pre facelift ae111s then at a guess its M12 1.5 or 1.25. Can't confirm though as I can only find my M12 1.75 tapAnd i'm pretty sure its not that.
So you could always try drilling the centre out a bit more
h8wrxs wrote:use a bit of kiwi diy skills and make it fit any way you can
its only a gearknob, dont bother going and buying a new one just drill it out and make it fit
