KIPH8N wrote:lyk wn it starts slipping..how does it happen??
Adamal wrote:If you match the revs, it should be all good.
You're only really going to bugger a clutch if you do silly things with it. Flat shifting, clutch kicking, not matching revs, failing at mad skidz au etc etc
KIPH8N wrote:Adamal wrote:If you match the revs, it should be all good.
even loosing traction on a rainy day?
KIPH8N wrote:How does a clutch wear out?
Does shifting down fade the clutch or shifting up on high revs? Or when the car lose's traction?
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
