AE111 rear brake disk depth?
Postby no_8wire » Tue Jan 11, 2011 10:26 am
Im looking at may be using a AE111 rear rotor/caliper for a conversion, but does anyone have the depth of pad that is used? Basically I want to find out the braking surface used.
no_8wire
Postby Bling » Tue Jan 11, 2011 10:50 am
Roughly 32mm width of the used section of the disc, on the SS setup I wrecked. Guess it depends on the model you want to know about
