are all cam belts equal
Postby h8wrxs » Wed Jan 19, 2011 1:32 am
my evo is in desperante need for a new cambelt
was just wondering is the average old repco spec cambelt kit for around $400 just as good as the hks ones you see in performance car?
are the hks type brands just for wank factor?
also is $400 at repco a good price for the belt, idler bearings, tensioners etc?
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby strx7 » Wed Jan 19, 2011 6:58 am
the gates belts repco sell have a 250,000km warranty i'm pretty sure
Re: are all cam belts equal
Postby cat007 » Wed Jan 19, 2011 7:35 am
h8wrxs wrote:
the hks type brands are just for wank factor
Postby Mr Revhead » Wed Jan 19, 2011 8:08 am
strx7 wrote:the gates belts repco sell have a 250,000km warranty i'm pretty sure
Really??
Postby strx7 » Wed Jan 19, 2011 9:18 am
Really??
pretty sure that is what I read on the box last time i had one
Postby tsoob » Wed Jan 19, 2011 9:50 am
I have a gates one... pretty sweet looking thing :D
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Py7h0n » Wed Jan 19, 2011 9:59 am
It a wear item and while gates my warranty the belt for 250,000km I am sure they will not give you money for new pistons, valves, machine work etc when it does break.
I can just imagine, "Oh sorry to hear that it broke, here is a new belt".
I believe in changing them more often rather than buying "Performance" belts.
Py7h0n
Postby cat007 » Wed Jan 19, 2011 10:08 am
Agreed
Postby Py7h0n » Wed Jan 19, 2011 10:10 am
Benefit of the JZ with a 2 piece pulley means it's a 15min job - I do it once a year now at the longest ($30 for a belt, why not :P).
Py7h0n
Postby touge_ae101 » Wed Jan 19, 2011 10:16 am
have heard and seen a few gates belts break after not so long so personally i would stay away. mark (whynot) had one break and destroy an engine and when asked about the warranty etc they didn't want to know about it.
a decent cambelt is made to stretch less so when there is a lot of load on the engine, the timing doesn't get retarded (have heard about 2-3deg) by the cambelt becoming longer. this is in a very extreme case mind you but it does make a difference.
just personally i wouldn't go for a belt that isn't OEM or decent aftermarket quality on an interference engine.
touge_ae101
Postby Py7h0n » Wed Jan 19, 2011 10:18 am
I personally like Toyopower belts from Partsmaster - Used both at high HP levels without issue so far.
Py7h0n
Postby Mr Revhead » Wed Jan 19, 2011 10:21 am
I've never heard of any belt breaking before it's time that wasn't caused by the waterpump/tensioner/other part.
However I did notice when at Toyota that gates ones will fail sooner than OEM. I'm talking like 20-50k over
Postby Py7h0n » Wed Jan 19, 2011 10:23 am
Yeah genuine Toyota belts are awesome! I ran my dads one on his 2JZ NA to 140km before I finally changed it (lazy streak) - It was also coated with oil from leaking cam seals.
Py7h0n
Postby Girvs » Wed Jan 19, 2011 11:28 am
Py7h0n wrote:Yeah genuine Toyota belts are awesome! I ran my dads one on his 2JZ NA to 140km before I finally changed it (lazy streak) - It was also coated with oil from leaking cam seals.
Toyota definitely did well on this engine. Only changed my tensioner and water pump at 180k. Though I run gates belts primarily due to a change in pulleys
Girvs
Postby MR2BOY23 » Wed Jan 19, 2011 11:33 am
I have always used, and sold bosch timing belts
MR2BOY23
Postby Dell'Orto » Wed Jan 19, 2011 7:36 pm
Gates belts are OEM spec, so if your belt is meant to be changed at 100k, then the Gates one is too.
In all my time of selling them, I've only seen one fail, and that was due to oil contamination...
Postby cat007 » Wed Jan 19, 2011 9:59 pm
Dell'Orto wrote:Gates belts are OEM spec, so if your belt is meant to be changed at 100k, then the Gates one is too.
How much oil does it take to start doing bad things with the belt? Soaked or the odd drip?
Postby Dell'Orto » Wed Jan 19, 2011 10:27 pm
Sorta in between. A continual small drip will screw it eventually, a crank seal failure will kill it in weeks.
Postby h8wrxs » Wed Jan 19, 2011 10:38 pm
so is $400 about right for a cambelt kit from repco, i think it was a gates belt it some with?
or can anyone recommend somewhere/ sell me a kit cheaper?
h8wrxs
Postby iOnic » Wed Jan 19, 2011 10:44 pm
The HKS etc belts aren't just for wank factor. They ARE actually stronger than OEM belts. Comes in handy when the engine is revving far beyond what the factory ever intended. Using an OEM cambelt on a 10,000rpm 4G63 (for example) is just asking for trouble. At those sort of revs there is so much stretch in the belt that you start getting inconsistent triggering and sync between the crank and cams when using a weaker belt.
If there is no reason for you to get one then you won't get any of the benefits of having one - much like most "performance mods".
Users browsing this forum: Bing [Bot], Google [Bot] and 16 guests
