Anyone got a pin out for this engine>?
AE25 wrote:go pickapart, pull ecu, take cover off, take pics of printed pinout on circuit board? (assuming its printed)
sergei wrote:No he is not kidding. The ECU pin out will be in repair manual, since the car has been sold as NZ (I assume as previa) there will be a repair manual with TNZ in English. There are also aftermarket repair manuals (like haynes) in your local library (and on torrents/rapidshare) that you can borrow/scan/download.
Oh BTW: if the resistor is blackened/burned it is most likely the output transistor that is upstream of that resistor is fried (just trace the tracks from resistor).
If these ECU are available from pickapart is is more practical to get ECU from there, that is if you don't have skills/equipment to repair your ECU.
3T-Rona wrote:sergei wrote:No he is not kidding. The ECU pin out will be in repair manual, since the car has been sold as NZ (I assume as previa) there will be a repair manual with TNZ in English. There are also aftermarket repair manuals (like haynes) in your local library (and on torrents/rapidshare) that you can borrow/scan/download.
just trying to do the most for the customer with the smallest amount of effort because no one wants to pay for anything sadly,
If you have tried ringing any of the franchise's in Tauranga you would know they generally dont give out that information.
3T-Rona wrote:Idle speed contrl 1 coil winding drawing excess current......
