Dim Headlight
Dim Headlight
Postby Garreth27 » Fri Feb 04, 2011 11:44 am
Got this annoying issue with my starlet. Since its now running I noticed one night that the passenger side headlight is really dim compared to the driver one. I tried changing the light bulb but still the same thing, its as if its not getting enough power. What should I look at that could be causing this.
Current Rides:
91 Gt Starlet - Forged 5efte Drag Toy
88 EP71 Turbo S Starlet Track Toy
99 SEX10 Altezza - Daily Driver
Garreth27
Postby sergei » Fri Feb 04, 2011 3:10 pm
Corroded contacts and or wire.
I had to rerun all head light wires (thicker gauge as well) to get headlight to be as bright as they supposed to be.
Postby strx7 » Fri Feb 04, 2011 5:03 pm
isn't a plastic lens which has been effected by UV by any chance?
Postby sergei » Fri Feb 04, 2011 5:12 pm
Also it is possible that there is wiring issue and both filaments (high and low beam) are on but in series.
Postby Stu- » Fri Feb 04, 2011 6:33 pm
Your talking about your EP71? Check the earths each side. Since you've had it painted there is a chance the earth contact to the shell isn't that great.
Project Thread
Stu-
Postby rodstr » Fri Feb 04, 2011 9:04 pm
this might be a silly question, but have you checked the fuse located with the other fuses in the engine bay?
rodstr
Postby Garreth27 » Sat Feb 05, 2011 2:57 pm
yea in the ep71 stu. Have checked fuses and replaced the relays. Will try cleaning up the contacts and paint today and see what happens
Current Rides:
Garreth27
Postby sergei » Sat Feb 05, 2011 5:39 pm
Garreth27 wrote:yea in the ep71 stu. Have checked fuses and replaced the relays. Will try cleaning up the contacts and paint today and see what happens
Got multimeter? Measure voltage at each pin on head light and post here.
