Lith wrote:Wrong... operator will set a fixed rate for the dyno to run through the rpm range on a rolling road, a retarder provides the amount of resistance required to maintain that rate and reports to the software the tractive effort required, then calculates from there. Its much if a muchness, in terms of real world likeliness.... except the hub dyno is more accurate as the control is finer and more direct due to a solid link so the tyres only serve to compromise accuracy.
Akane wrote:All dynos work on the basic principle of having a set resistance which the software calculates the time it takes to spin, unless you have one of the better hub dynos which you can set and HOLD the RPM which you can tune a specific load cell point. Something a rolling road cannot do.
except hub dyno is LESS accurate when it comes to knowing approximate what power you have available to the treads, because there's none? Might as well throw your car on it's brake discs and drive around.
You DO WANT to include that variable of rubber sizes / type / PSI of air inflated, size and shape / design of the wheels IN YOUR DYNO, to see what power that is available to you, when you drive
iOnic wrote:I don't think you understand how dynos work or what their actual purpose is. You're purely interested in getting a particular number and being able to tell people that you got that number "at the wheels bro". You couldn't care less about how accurately that number reflects what's actually happening as long as you've got 300hp at the treads. For you, a dyno is less of a tuning tool and more of a penis measuring device.
Carry on.
How do you think a Dyno works??
BZG|Bling wrote:solitaire wrote:Dont forget about it being a hot day...
True forgot that point.
Also don't forget "XX Kw on hub dyno, will have more power though as had shit tyres on so was probably slipping heaps"
Timmo wrote:BZG|Bling wrote:solitaire wrote:Dont forget about it being a hot day...
I thought it went the other way- Nice sticky tyres will read lower because they stick to the rollers- For higher numbers it's better to run cheaper/harder compound.
iOnic wrote:You seem to be really knowledgeable about how dynos are designed and how they work. How many different dynos have you had the opportunity of tuning/diagnosing vehicles on?
