Akane wrote:Is it possible to have stripped gear on the sender.. although 1 in a billion chance....... shrug........
matt dunn wrote:[
It is AE101? S/h senders for that era are getting hard to get, as they corrode off the 5V feed wire and are a real common problem,
that usually kills them completelt, but they do also start to drop pulses out of the signal which can only really tell on a scope.
Same thing happens in Isuzu's but they affect the Auto trans and not the speedo.
It's all to do with the sample rate that the device uses from the sender.
1I1 wrote:Looks like speedo sensor didn't sort it![]()
Driving along at 50km/h last night speedo was reading 0km/h yet the trip meter and odometer were working fine along with RSM.
And out in the country while doing 100km/h speedo was reading around 80
