megasquirt?, link?
megasquirt?, link?
has anyone got alot of experiance with a megasquirt ecu?
im am looking at buying a new ecu for my blacktop turbo
and im not realy sure whats gona give me the best for the cheapest
also where is the best place to buy ecus as trade me has a very limited choice and very little info
im not realy interested in a flashy g4 or anything just something thats affordable and gona run my car well
girl: can I trust you?
me: you can trust anything
- tsoob
- Toyspeed Member
- Contact:
g4 atom?? pretty cheap and has fantastic capability for that engine
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
15 Parkway Drive
Mairangi Bay
09 486 5317
In terms of bang for buck, Megasquirt is lightyears ahead of Link. Features are much the same between the two.
For the price of an entry level G4 Atom you can have a full featured MS.
I built one last year for my partner and not sure if I'm allowed to say how much it came up to
but it was under $1k including shipping from the states + a lot of addons and it's a full standalone ECU that plugs into the factory loom, full sequential fuel and ignition, launch control, boost control onboard, bluetooth connectivity, onboard ignitors, onboard map sensor, closed loop afr, flexible fuel maps, closed loop knock control + waaay more.
A lot of those features are only available on the top of the line Link G4's and you don't have the flexibility of being able to just plug the stock ECU back in if the car is sold or to diagnose problems...
Anyway not trying to be a salesman
but if you're good with electronics and like to tinker with things then you'll enjoy the MS. If you just want something that works with no mucking about and everyone is familiar with - Link all the way
well thats good news considering the price of the 2
this is the mega squirt im looking at getting
http://www.trademe.co.nz/Browse/Listing ... =356980185
the guy says for extra he will do a base fuel and ignition map plus the latest software and it come with the soft ware for a pc and all the cables etc
what do you think?
what do you think?
Who's going to install/tune the ECU for you? That'll ultimately decide what ECU you go for.
Buying a Megasquirt may seem like a good idea but most tuners don't know anything about them and many will outright refuse to even touch it so unless you can do a lot of it yourself - get a Link. Megasquirt isn't just a case of buying the unit, installing it and taking it to a tuner.
- Toyspeed Member
- Contact:
Yep, i totally agree with Chris on this.
Im going G4 on my R33, basically due to 2 reasons. Firstly luckily they make a plugin for me (GTRLink) and secondly, the guy ill get to tune mine does links, and recently got 326rwkw at 12psi from a mates RB26 on a GTRLink.
Im also not confident in myself enough to make an ecu
- QikStarlie
- Toyspeed Member
- Contact:
link = easy
megasquirt = some dicking around. but hell of alot cheaper.
also on the plus side for link is the support and tuners in nz. but in saying that i found it pretty easy to tune my ms3 after tuning links
your probably better off buying a prebuilt kit off diy autotune rather than buying off that guy on trademe. what hes selling is a ms1 on the old version 2.2 board. basicly the cheapest oldest megasquirt you can buy. with current code i'd rate them a bit better than a v5 link, but not as good as a g3 or greater link. a mate brought one off him, to run on a na smallport. was alot of messing around as we wanted to run waste spark and stock cas. in the end it was straight foward to tune and runs fairly nice. but would have been better off to buy a 2nd hand v5 link tbh.
ms3 or ms2 are worth looking at.
iOnic wrote:Buying a Megasquirt may seem like a good idea but most tuners don't know anything about them and many will outright refuse to even touch it so unless you can do a lot of it yourself - get a Link. Megasquirt isn't just a case of buying the unit, installing it and taking it to a tuner.
I've never played with one, but remember seeing a post from one of the guys from Shred Motorsport in Wellington saying that from Aaron's efforts tuning a car with a MS saying it seemed like there was no interpolation whatsoever between zones. Possible its just operator error?
2007 Mazdaspeed Axela
- QikStarlie
- Toyspeed Member
- Contact:
nar they all interpolate. unless some old code/firmware didn't do it. the ms1's even have movable bins/ rows columns, unlike the old g1 links.
if your tuner can't figure out how to tune a megasquirt. find a new tuner. sure you would expect them to take longer to tune it, over what they are familiar with, finding there way around the software etc.. but its not that hard
Yeah I'd put it down to operator error/inexperience. Even the earliest Fuel only code/firmware did it. The ECU is only as good as the person tuning it. Even a G4 Extreme can appear to be total rubbish in the wrong hands.
- tsoob
- Toyspeed Member
- Contact:
whats your budget for ecu, install and tune all up?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
15 Parkway Drive
Mairangi Bay
09 486 5317
iOnic wrote:Yeah I'd put it down to operator error/inexperience. Even the earliest Fuel only code/firmware did it. The ECU is only as good as the person tuning it. Even a G4 Extreme can appear to be total rubbish in the wrong hands.
Guess I am overdue to take a good look at these things, I've known about them for long enough but never really done anything about it.
I would put it this way:
If average turbo I would go with Link, since I will shift responsibility of tuning to someone else. It is much easier to blow up a turbo engine with bad tune.
If el-cheapo N/A 20v I would go with megasquirt.
If high end 2ZZGE or 2GRFE, I would go with Motec.
Don't forget with megasquirt you will have to get wideband Oxygen sensor and supporting electronics for DIY tune.
i heard a quote from a top if not the top auckland based tuner at the recent SI champs it was
"tuning cars with microtechs is like doing brain surgery with a hammer"
cant argue with that.
cant beat a link man, super easy to tune and very driveable.
my 16v 4agte spent less than 2 hours on the dyno with a link G1 V5.
sure its getting pretty old now but do you really need all that fancy bullshit on a mostly road car......no you dont.
if i had to buy a new comp it would be a atom without a doubt
i was really hoping not to spend more then 1000-1500 on purchase and tuning
but im geussing im gona have to spend a bit more than that
i dont know any tuners in wellington or where the best place is to buy ecus
the only ones ive seen are the ones on trade me and im sceptical of thoes
looks like the megasquirt on trade me is shit.
where can i go for a good reliable affordable tuner in wellington?
what i buy is possibly gona come down to what the tuner has more experiance with
would it be fair to say that if i buy a megasquirt it would be cheaper but the tuning would be more expencive because it would be harder?
meaning that all up it would be relatively the same price to buy a link and have it tuned except minus all the hassels????
